Amazing $350 A90 Subwoofer Upgrade and it’s Removable
Pizza
Mitch
Michigan, USA
does the amp come with its own adjustable Bass knob?
Has anyone simply upgraded their OEM subs with "Bavsound" subs? claim thats all you have to do, and you'll get much more Bass.
iirc someone on the bimmer forums measured the Bavsound subs vs stock in their Z4 and the Bavsounds frequency response was notably worse than stock.
Danimal
Dan
Chicago
2021 Supra Premium 3.0
Finally got my sub installed - so happy with the audio now! Well, except for the rattle in the passenger door I haven’t tracked down yet…
mittenstheg
Sol
MKV Supra
digdeep0169
Ray
Albuquerque, NM
www.instagram.com
2022 Toyota Supra GR 3.0 Premium Tungsten Silver
The way homie never replied. I’m mad lol.
I assume it’s the 10” JL?
It’s this: https://www.jlaudio.com/products/acs110lg-tw1-car-audio-powerwedge-amplified-subwoofer-systems-93334.
This will also fit, but the driver is smaller.
https://www.jlaudio.com/products/cp...d4ECIkkVALn95D9Pv_Jzj9z3QRCq8kb5P1OmHzNVBqur5
10" sub on only 400W. i'd be curious how it sounds, when turning up the Vol on OEM speakers.
does everything come up at the same level? Clarity, etc.
mittenstheg
Sol
MKV Supra
I’ll be getting it installed soon. I got the sub/amp combo for $120 off.
You can use a bass knob to adjust the sub gaines more independently.
The last system I had, was 2 12’s used 600w AMP and it was overkill for my dodge dart. 10” Sub on 400W in this small cabin may actually be too much.
The accuracy of the sealed box should be pretty good. I learned that the reason the HK mid-base may be sealed is to make the bass more accurate and less boomie.
After I tuned the audio the sound was pretty good even without a sub.
if you wanted you can go with these but they require an AMP.
mittenstheg
Sol
MKV Supra
I thought I'd contribute a pic of my install. Not the prettiest, but it is removable and I do retain most of my storage space. I can still carry a set of golf clubs in the back. IMHO the mod adding the ports are fine for most types of music, but occasionally, I want to listen to booming bass and that's when the stock subs fall short even with the mod. That's when you do need another amp and sub. I'm a little partial to JLs, they've been my goto subs for the last 30 years. The bass is now is more than enough for me, especially in a small cabin and is still clean sounding.
I did this install it worked very well. This is great bass response. The subwoofer bangs too hard in all honestly for this cabin size.
Xscity
Cris
Clermont, FL
Toyota Supra
Hoping this will help other members out. Well I tried the standard port addition upgrade without much success. I wanted a subwoofer that could hit hard and loud,, not break the bank, doesn’t take up too much space and could be easily removed for track days. So I did some research, spent $350 and 4 hours and can’t believe how amazing this subwoofer sounds. Very easy to duplicate and everything came from Amazon. I used Velcro to hold the box and amp in place.
Atrend Bbox 12AME 12-Inch Single Sealed Shallow Mount Downfire Enclosure, black (12AME*) https://www.amazon.com/dp/B01BXE8ZW6/ref=cm_sw_r_cp_apip_7zyWBh2Ohy2E1
PIONEER TS-A3000LS4 12" Shallow-Mount Subwoofer with 1,500 Watts Max. Power https://www.amazon.com/dp/B082FQRDKS/ref=cm_sw_r_cp_apip_yNk8SqrduuZE6
Stinger Audio MT7001 Monoblock Class D Mosfet Power Supply Amplifier with Remote Subwoofer Level Control,700 Watts RMS. https://www.amazon.com/dp/B0BMVXC6HZ/ref=cm_sw_r_cp_apip_IbxJFVd7iaDSw
PAC SNI-35 Variable LOC Line Out Converter 1.2x6.25x5.9 https://www.amazon.com/dp/B001EAWS3W/ref=cm_sw_r_cp_apip_TLwZalFspLwzy
Scosche Install Centric ICAK8 True 8 Gauge Hybrid OFC 2-Channel High Current Amplifier Wiring Kit Complete Car Amp Kit Twisted Pair Audio Cables, In-L https://www.amazon.com/dp/B08FRT6CL9/ref=cm_sw_r_cp_apip_iVWCgUuRdKcvO
Fairfield The Original Poly-Fil, Premium Polyester Fiber Fill, Soft Pillow Stuffing, Stuffing for Stuffed Animals, Toys, Cloud Decorations, and More, https://www.amazon.com/dp/B004ALQ0M2/ref=cm_sw_r_cp_apip_KMamhmIOHJB59
VELCRO Brand Extreme Outdoor Mounting Tape | 20Ft x 1 In, Holds 15 lbs | Strong Heavy Duty Stick on Adhesive | Mount on Brick, Concrete for Hanging, 3 https://www.amazon.com/dp/B09BNPHCZX/ref=cm_sw_r_cp_apip_h3yCf6bj8OIpl
Is the bass decently low? I may replicate this and order all items.
